Online Now [876]:
Visitors: 876
Today: 309112
Total: 151428542
Forums › The Car › 206 Problems › Losing coolant? Temp over 90...
Jammzo
PostPosted: Thu Aug 27, 2015 11:57 am Up
Head gasket/water pump/radiator replaced.
Car was cutting out when approaching junctions doesn't happen no more.
My last problem in which if this can't be solved im thinking about part ex'ing.
Any help would be great to solve this!
I am now currently losing coolant, 70-80 mile journey and it is easily noticable I am loosing water.no oil in the coolant. there are absolutely no visable leaks.
Car runs at 90 degrees at speed, when slowing down it goes over 90 to around 100 and the fan kicks in. This happens every journey long or short. Any way to help me stop losing coolant? I have had a 206 before this car and the temp was glued to 85 and i never had this problem i had only ever had the fan kick in once on an older 206 so why every journey is it doing it on this?
engine 1.4 8v.
thanks!
conker1221
PostPosted: Thu Aug 27, 2015 2:47 pm Up
My 8v lump runs below 90 at speed, closer to 80 than 90 actually.
What time does the fan kick in? If coolant is going it must be leaking somewhere.
Jammzo
PostPosted: Thu Aug 27, 2015 3:27 pm Up
fan kicks in soon as it raises over 90!
PostPosted: Thu Aug 27, 2015 4:13 pm Up
What about coolant in the oil?
Jammzo
PostPosted: Thu Aug 27, 2015 4:52 pm Up
there's no coolant in oil at all :/
Jammzo
PostPosted: Thu Aug 27, 2015 4:54 pm Up
I have had one situation where the water was once leaking out of the top part through the cap. but hasn't done this since.. so ive ordered a new cap to see if that helps. any other ideas would be a massive help. cheers for replys
ukskater01
PostPosted: Sat Aug 29, 2015 3:25 am Up
On other cars I've had them lose coolant but couldn't find a leak. Ended up finding a pipe from the egr cooler leaking on to the exhaust and evaporating. Try and get it in the air while running to look for leaks
Connor_1992B
PostPosted: Mon Aug 31, 2015 4:56 am Up
Probably leaking from pipe at the water pump. Right next to the exhaust manifold.
sean.r.steward
PostPosted: Tue Sep 01, 2015 3:45 pm Up
might be a leak between hot and cold. is the pressure in the system when its hot check by
squeezing a rad hose. of dont remove tank cap
