Online Now [242]:
Visitors: 241
Today: 118338
Total: 155987676
Forums › The Car › 206 Problems › Gti 180 temperature issue?
Hansum
PostPosted: Fri Aug 28, 2015 3:23 pm Up
Hi all, only had my car a couple of days, noticed today that the temp rises to 100 in traffic then shoots back down to 90, is this normal, I'm sure it didn't do it when I bought it, heard somewhere that there is a temp sensor, could it be faulty? Can't hear the fan cutting in but as soon as it hits 100 it drops back to 90.
PostPosted: Fri Aug 28, 2015 5:10 pm Up
Switch your air con on at idle. Does the fan kick in?
sean.r.steward
PostPosted: Tue Sep 01, 2015 3:05 pm Up
run it hot with out ac on untill you see the rad fan kick on and off repetitively.
if it is, then all is well .
