Online Now [1180]:
Visitors: 1179
Today: 39969
Total: 156147257
Forums › The Car › 206 Talk › New ecu - cable throttle on a 180
Forum Index › 206 Talk
Project2062014
PostPosted: Mon Aug 31, 2015 5:39 pm Up
Hi peeps.
I'm wanting to put a cable throttle body or bodies given the best opinion & price.
The reason for this is so I can run a better ecu .
I have vems 3.3 in mind or mega squirt 3.
Vems is plug & play just extra! ££
So there's a manifold for jenveys that let's me keep the PAS pump. £300 with the injector holes drilled . Also can be drilled out to 55m inlet.
Twin jenveys seem affordable and will fit. For around 400.
There also single inlet jenveys throttle bodie 70mm around 280.
Am I going to gain a lot more bhp with x4 single bodies over a single 70mm bodie? +( opition to turbo in future )
Does any know the situation fitting the cable accelerator pedal ? straight Swap for a old preplex 206 throttle pedal?
Looking to change cams if affordable .
I've read on the 804.
Whats the best cams to keep the vvt & get max bhp without changing rods springs ect?
Is it better to lose vvt ?
Cheers
sean.r.steward
PostPosted: Tue Sep 01, 2015 2:55 pm Up
PostPosted: Wed Sep 02, 2015 5:09 am Up
You won't get the car up and running on Jenvey throttle bodies for £400!
Project2062014
PostPosted: Wed Sep 02, 2015 6:41 am Up
£1200 will & that's with the ecu in that..
probably cost a lot more for mapping the thing..
Great advice
