Online Now [434]:
Visitors: 433
Today: 34548
Total: 127856833
Forums › The Car › 206 Talk › 206 Climate control conversion
FrankAteMyName
PostPosted: Tue Aug 11, 2015 2:01 pm Up
Hi guys
You'll have to excuse my incompetence. I'm new to all this. I have a 1.4 8v with air con and manual control. I took the plunge and decided to buy a digital control panel and blower motor. I also have the servos and a single temperature sensor. I just have no idea what to do with it and was wondering if anyone here could lend a hand.
Cheers in advance
Frank
PostPosted: Tue Aug 11, 2015 5:42 pm Up
Do you have the loom around the heater box too?
If its preplex just remove the dash board, fir and away you go. Multi you need to reconfiqure the bsi as well
FrankAteMyName
PostPosted: Wed Aug 12, 2015 11:03 am Up
Thanks for yoyr reply. Sorry I'm new to this. How will I know if it is preplex or multi? It's a 56 reg if that helps?
Cheers
My cars:
206 Urban 1.4 8v 3dr '56 - China Blue - 70k Miles - Climate control retrofit, cruise control retrofit - Dead (Breaking)
206 GLX 1.4 8v 3dr '03 - 100k Miles - Obsidian Black - Black masked headlights + front fogs, Faster sunroof, Colour matched exterior trim - SOLD
206 2.0 GTI 138 '03 - 58k Miles - Onyx Black - 17" 180 Alloys - Current
206 2.0 GTi 138 '03 - 120k Miles - China Blue - New Track Toy (ON THE WAY)
FrankAteMyName
PostPosted: Wed Aug 12, 2015 12:35 pm Up
Okay, I did some digging and it would appear it's a multiplex version. Is this going to throw a spanner in the works at all?
My cars:
Imelliot
PostPosted: Fri Sep 04, 2015 9:24 am Up
I have a pre plex what's involved in changing it from aircon to climate control?
FrankAteMyName
PostPosted: Sun Sep 13, 2015 3:23 pm Up
onFrom what I understand - On the preplex models you need the control panel, wiring loom, cabin temp sensor, external temp sensor and I needed the entire heater matrix assembly with servos and assorted sensors. To install the new matrix am I right in saying you may as well drain the engine coolant and clean the system? That's what I had to do and it handles long traffic queues much better now.
When people told me it was more hassle than it's worth I didn't believe them but trust me it's a nightmare. I will try and make a decent guide for the Multiplex conversion as there isn't one around (to my knowledge). I'll keep you guys updated with how it goes.
Imelliot
PostPosted: Sun Sep 13, 2015 3:36 pm Up
What's really the benifits of having climate control? There is a 206 in my local breakers with climate control was going to take everything from that he said would be looking about 40 quId for everything
PostPosted: Mon Sep 14, 2015 1:01 am Up
Most people on here hate the climate control system as they don't understand how it works.
FrankAteMyName
PostPosted: Sat Sep 19, 2015 12:52 pm Up
The thing I like about climate control is the simplicity. Set it once and it will keep the car St that temperature for you. No faffing about with knows trying to get the perfect temperature for it to only change next time you're driving.
Make sure the breaker also gets you the heater matrix and assembly. The assembly supports the installation of digital servos for controlling air flow, temp mix, recirculation etc. It also supports all the sensors except cabin and exterior temperature. Which are found behind the grill in the passenger airbag and in one of the wing mirrors (I forget which).
