Latest: heikkisj
Overall: 17126
Online Now [61]:
Visitors: 60
Today: 15193
Total: 100387905
Forums › The Car › 206 Problems › Rear stabilizer/Trailing Arm bar bracket Part Number
leopoldpatriot
PostPosted: Thu Oct 01, 2015 12:11 pm Up
Hi
Anyone know the part number for the bracket that the rear stabilizer bars fitted to. The ones that are bolted to the trailing arm. Mine have stripped threads.
any help, much appreciated
PostPosted: Thu Oct 01, 2015 12:15 pm Up
You mean anti roll bar?
leopoldpatriot
PostPosted: Thu Oct 01, 2015 12:30 pm Up
Hi
No, it's the stabilizer bar that's fitted to GTI 180 & SW's. 2 x thick arms fro centre of rear axle to each trailing arm
Sim
PostPosted: Fri Oct 02, 2015 2:28 pm Up
on 180: REAR AXLE TRANSVERSE BAR
5150 91 LEFT
5150 92 RIGHT
EV
Jag S(crapped)- & X-Type
GTC VXR (sold)
