Latest: sparrowdclxvi
Overall: 17139
Online Now [71]:
Visitors: 70
Today: 23866
Total: 113298836
Forums › The Car › 206 Problems › Cigar lighter - need new one
Hogweed
PostPosted: Fri Oct 02, 2015 11:46 am Up
Hi all – just tried to use the cigar lighter for the first time, and it’s knackered – all rusty inside, don’t think it’s salvageable. How hard is it to get out and replace?
I pulled the gear gaiter up, and could reach it, but couldn’t feel how it was released…
Thanks a lot
Hoggers
mtempsch
PostPosted: Fri Oct 02, 2015 1:27 pm Up
Thanks a lot
Hoggers
Small tabs in the orange plastic. See pictures in this eBay auction
I'll try a direct inclusion of the image too:
Quickest way to get it out is probably to break off the orange rim and push it down.
Mounting the new requires to attach the bulb holder after the lighter as such has been pushed in place (if you want the ring to light up). Don't know if that's doable through the openings or if you need yo undo the console (IIRC pull off the handbrake 'cover', loosen the gaiter, unclip the switches from the harness connectors and undo one screw at the very rear of the console (hidden behind a flap you need to pry open))
Silvermetallic 2004 206 RC
Hogweed
PostPosted: Fri Oct 02, 2015 4:07 pm Up
Thanks that's great Wink
Ross74H
PostPosted: Sun Oct 04, 2015 4:36 pm Up
Haynes manual says you need to remove the centre console section and remove the plug from underneath and then take it out in two parts - the lighter section and then the illuminated yellow plastic ring section.
But the Haynes manual always seems to take a harder route than neccessary.
mtempsch
PostPosted: Mon Oct 05, 2015 2:06 am Up
Probably the 'proper' way to do it, if you're not willing to break it. But if it's already beyond repair...
Hogweed
PostPosted: Mon Oct 05, 2015 3:33 am Up
Thanks guys, both solutions very much appreciated - I'm afraid, in this case, it's going to be butchery - as you say, the old one is beyond use.
Hogweed
PostPosted: Tue Oct 06, 2015 9:16 am Up
Ummm... sorry if this should be really obvious, but I break things Sad
How do you detach the bottom black section (which includes the connector) from the top orange/silver section?
I need to do this to get it through the hole... thanks
Hogweed
PostPosted: Thu Oct 08, 2015 1:12 pm Up
Well, tried everything, and in the end had to destroy the old one to remove it. Not much of a loss really! New one in and working, thanks again Very Happy
