Latest: ArtistKS
Overall: 17145
Online Now [302]:
Visitors: 301
Today: 34145
Total: 115933828
Forums › The Car › 206 Problems › Strange juddering
Strange juddering
MrMac
PostPosted: Thu Nov 12, 2015 3:06 pm Up
I have posted before about lumpy idle...and that problem has more or less gone. But now I have another problem developing. When at low revs...warmed up or cold..say pulling away from lights, the car judders, like it has the wrong fuel, then rectifies itself. I have looked after the car and have kept up with servicing. Timing belt/water pump changed at 140000 miles, oil and filter changed four months ago, new discs, pads and brake fluid changed last month, and all new Bridgestone tyres. On the motorway it is as smooth as butter and very very economical. I had it scanned today, no codes. They took the plugs out all are in perfect condition. They were changed last November. Coil pack is only six months old and I tried a second hand one to. Oh I have also changed and cleaned the throttle body, ICV, O2 sensor and the MAF sensor over the last year. Any ideas? I'm stumped!
2000 1.4 petrol LX
PostPosted: Thu Nov 12, 2015 4:04 pm Up
Contamination on the clutch?
MrMac
PostPosted: Thu Nov 12, 2015 5:00 pm Up
Interesting....I have not come across this before. It is the original clutch and is fine changing up and down.
MrMac
PostPosted: Thu Nov 12, 2015 6:25 pm Up
Defo not the clutch...just drove home from work and it was a nightmare. Even in 5th gear it was juddering...had to knock in into 4th to rev it, then back into 5th. Its like it isn't getting the right amount of fuel...injectors? But then again, wouldn't a dodgy injector foul up a plug?
Danpemble
PostPosted: Fri Nov 13, 2015 5:36 am Up
I did have a similar problem with mine. Tho mine is 1.4 hdi. Turned out the gearbox was on its way out. Use to make a screech noise on pulling away in 1st and reverse. And driving along it would start to judder as if it was going to cut out. Worse going up hill. I thought it was fuel related at first until a loud banging started.
MrMac
PostPosted: Fri Nov 13, 2015 6:09 am Up
God I hope its not the gearbox...I'm as poor as a mouse at the moment! I just did a BSI reset and put a different coilpack in...took it for a short spin and no juddering....lets see how it goes on a long run later.
Motorracingbruce1980
PostPosted: Fri Nov 13, 2015 7:03 am Up
It Sounds more like a Missfire if its coming and going. Mechanical issues to to stay and not dissapear.
Project China Blue 206 GTI
MrMac
PostPosted: Fri Nov 13, 2015 8:07 am Up
I'm thinking injectors....
MrMac
PostPosted: Fri Nov 13, 2015 9:59 am Up
Just been on a long drive...35 miles...no juddering.
