Latest: heikkisj
Overall: 17126
Online Now [68]:
Visitors: 67
Today: 16653
Total: 100300572
Project sleeper
Go to page Previous  1, 2, 3 ... 75, 76, 77 ... 84, 85, 86  Next
PostPosted: Sat Nov 14, 2015 4:36 am Up
And the main reason for tuning the 138 engine is because that's what was already in the car!
drmo
PostPosted: Sat Nov 14, 2015 9:33 am Up
Yes, of course. I didn't say that the engine is rubish, just that the 180 is a much better option to start with, and not all tuners know how to tune vvt (most think it is just an on/off thing, like with 2.2 16v).
Edward, did you solve the peaky nature of the engine?
www.enigma-motorsport.si
www.facebook.com/Enigm.../timeline/
PostPosted: Sat Nov 14, 2015 2:44 pm Up
It should be as good as it can get - apart from a compression increase, a N/A engine will always appear relatively gutless compared to my daily driver with 236lb ft of torque at low revs!
drmo
PostPosted: Sat Nov 14, 2015 3:25 pm Up
With this spec cams:http://www.pipercams.co.uk/pipercams/www/product.php?pid=GTI2BP285
I would suspect a broader torque curve and much less peaky nature of the engine. May I suggest someone to look at cam timing? I've seen this before, when cam timing was off.
You still have that good looking Longman's plenum over itbs?
Lateral_Soup
PostPosted: Sat Nov 14, 2015 4:37 pm Up
Edward wrote:
But mine has a Longman head which will be better than the 180 head. For the road there is no point in fitting longer duration cams than I have fitted. The only advantage that the 180 would offer me is the higher compression and stronger bottom end.
The 180 does have bigger valves but with that comes VVT which makes life more difficult with choosing cams and to take full advantage you need a more expensive ECU which has variable cam timing control rather than the 'on/off ' control that the Omex 600 has.
ok well yea that makes sense, I'm pretty good with cars but I'm quite new to the newer peugot engines. Cheers for the advice guys, looks like I've got a fair bit of reading to get through lol Cool
Lateral_Soup
PostPosted: Sat Nov 14, 2015 4:38 pm Up
PostPosted: Fri Mar 11, 2016 11:50 am Up
Ooh a bit more spending....this can only mean one thing!
PostPosted: Fri Mar 11, 2016 12:28 pm Up
New rubber? That mean it might get a bit further than the end of you drive sometime soon? Surprised
PostPosted: Fri Mar 11, 2016 12:43 pm Up
Yep. Didn't want to fit new tyres if the car wasn't going to be used as they just age....so now that the weather is looking better I'm going to get it used.
PostPosted: Fri Mar 11, 2016 1:39 pm Up
Surprised I think I need to go sit down....
When was the last time it was on the road?
PostPosted: Fri Mar 11, 2016 2:35 pm Up
I think it was September 2012!
PostPosted: Sat Mar 12, 2016 6:15 am Up
£14 spent the other day. I noticed ages ago that one wheel was slightly difficult to turn by hard. The caliper was sticking slightly but the sliders were free to move when the caliper was removed. As soon as the slider bolts were tight it stuck again.
So I ordered some new sliders from Brakes International for £14. Problem fixed!
The old sliders did have some polished marks on them so that could suggest they weren't 100% straight. Who knows.
macj
PostPosted: Sun Mar 13, 2016 10:09 am Up
and the new ones are prettier Wink
PostPosted: Sun Mar 13, 2016 11:53 am Up
Yes they are nice and shiny ! Might try and get it MOT'd this week.
macj
PostPosted: Sun Mar 13, 2016 12:12 pm Up
I think we can expect a nice shiny clean pass there as well
Page 76 of 86
