Posted: Sun Nov 22, 2015 11:08 am |
Hi everyone,
The multifunction display on my 206 (2001 1.6 16v GLX 5d) has broken and I'm unsure how to fix it.
[img] [/img]
The ribbon cable which connects the display to the circuit board has become detached (see photo). Is there any way to fix it or do I need a whole new unit?
The serial number is 96424922ZR 4.8. If anyone has one for sale please let me know!
Cheers,
Kieran
Posted: Sun Nov 22, 2015 11:57 am |
You will need a hot bar arrangement to stick that back on, just replace it its not worth the hassle as that will give you loads of problems and you will destroy it trying.
Posted: Sun Nov 22, 2015 1:24 pm |
Ok thanks for the advice.
Will I have to replace it with an identical display or will any 206 display from that year work?
Posted: Sun Nov 22, 2015 2:01 pm |
Did it ever work? Looks like the pin is missing too and requires soldering back on.
Displays work on connection type. You need a PPT30. Go for the same multi line display if you can get your hands on one.
Posted: Sun Nov 22, 2015 2:38 pm |
It kind of worked but there were a few pixels missing and the bulbs seemed pretty dim. That's why I took it apart, I thought it would be a simple soldering job. How wrong was I!
There's a couple of PPT30 displays the same as mine on ebay atm, I'll get one of them.
Thanks for the help!
Posted: Sun Nov 22, 2015 4:07 pm |
sloposse wrote: |
You will need a hot bar arrangement to stick that back on, just replace it its not worth the hassle as that will give you loads of problems and you will destroy it trying. |
Don't think even a hot bar would do it - some of the pads on the flex are completely gone, so would require jumping tiny wires from the board pad to a bit further up the flex... Not completely impossible, but a bit too high on the P.I.T.A. scale for me to try if it was mine.
| Silvermetallic 2004 206 RC | |
