Online Now [606]:
Visitors: 605
Today: 134012
Total: 154941842
Forums › The Car › 206 Talk › 206 not starting - help!
Forum Index › 206 Talk
PostPosted: Fri Nov 27, 2015 4:04 pm Up
Hi guys,
After some help please!
My car is just not starting!
I turn the key and can hear it just about to start but then it doesnt!
So it gets real close but then stops.
Any idea on what I can start with?
edit: I must add, recently it hasnt been idling smoothly. If that helps to understand what it could be?
rallakias
PostPosted: Fri Nov 27, 2015 4:18 pm Up
Does the fuel pump working?
PostPosted: Fri Nov 27, 2015 4:20 pm Up
How can I tell?
Its that what I can hear before I fully turn the key to start?
rallakias
PostPosted: Fri Nov 27, 2015 4:34 pm Up
Yes it's a sound underneath the rear seat... If the pump works fine maybe check the plug of the crankshaft sensor..or maybe the spark plugs
PostPosted: Sat Nov 28, 2015 3:12 am Up
ok update. It started fine today multiple times. On the first go it took a few seconds but did start.
For the first time, there was this tapping noise from the engine near the coilpack/spark/injector area.
Any ideas? Might change the coilpack first?
It still wasnt idling smoothly either.
youtu.be/_nGNPi3dMuA
PostPosted: Sat Nov 28, 2015 6:52 am Up
I replaced the spark plugs and coilpack and starts first time and easy now! pff!
rallakias
PostPosted: Sat Nov 28, 2015 7:40 am Up
Nice...from the sound of your video maybe you may also check valve's clearance..
PostPosted: Sat Nov 28, 2015 8:45 am Up
VVT solenoid clean & working correctly?
PostPosted: Sat Nov 28, 2015 9:33 am Up
Valve clearance and VVT solenoid. Right, both on my list.
Let me check the Haynes for directions and report back after its stopped raining Laughing
PostPosted: Sat Nov 28, 2015 9:36 am Up
Hydraulic tappets on ET3 engine, there non adjustable.
PostPosted: Sat Nov 28, 2015 9:47 am Up
Okay!
Also, I just remembered. When I plugged into the OBDII port, one of the readings is for the throttle and it showed on even when not pressing it (like 1.7% or something!).
Do I also need to think about an idle control valve? (I know its drivebywire so unsure how this ties with idle control )
PostPosted: Sat Nov 28, 2015 9:52 am Up
Fly by wire throttle on ET3.
The throttle body is a known weak spot, I had to replace the one on my GFs 206 due to poor idle & throttle control.
PostPosted: Sat Nov 28, 2015 9:54 am Up
Alright, appreciate the pointers mate. Given me somewhere to start!
PostPosted: Sat Nov 28, 2015 10:01 am Up
A good 2nd hand throttle body & resetting auto adaptation cured the GFs 206.
Software update is also worth it for the ET3 lump.
There's a manufacturer part number on the throttle body, you can use that to match it up as its used on plenty of other PSA products.
PostPosted: Sat Nov 28, 2015 11:37 am Up
Didnt realise she didnt start for you as well mate!
When you say non start, no cranking or turning over?
