Hi, new to site, I have a 51 reg 1.4hdi with the old style lights and a friend had an 04 with crystal lights he was scrapping so I had the front and back lights, my problem is now when fitted everything works fine apart from when I engage main beam I lose dipped beam! I only get one or the other! Any ideas
Cheers
Posted: Thu Dec 03, 2015 12:45 am
We need to know if your 206 is non plexed OR multiplexed, 51 plate is the change over point.
The way to get the crystal headlights working correctly is different.
Non plexed you simply change the headlamp stalk.
Multiplexed you use Peugeot Planet software & change a setting in BSI configuration.
Interactive software released under GNU GPL,
Code Credits,
Privacy Policy
