Online Now [3098]:
Visitors: 3098
Today: 301108
Total: 153139035
Forums › The Car › 206 Problems › Will axle fit?
Will axle fit?
Ross74H
PostPosted: Tue Dec 15, 2015 4:48 am Up
My So has developed the dreaded wonky rear wheels issue so I have been looking at new axles from the GTi 180 so I can kill two birds with one stone and also convert to disks at the rear.
Unfortunately, the original rear axle from a 2003 has been sold. I have found another that is apparently from a 2004/5 model. Will thus have Abs plugs that are compatible with those on my 2003 (53 Plate) SW?
Want to make sure it will work properly with my car before I spend out on it!
MrWhite
PostPosted: Tue Dec 15, 2015 5:32 am Up
If you are converting from drums to disk you also need the handbrake cable. an the pick up rings in the gti 180 axle will be different to yours on your drum axle. When I had mine converted I had the rings taken off the old axle and pressed onto the new one so I could keep my existing sensors and plugs.
My 206 Project Thread
Ross74H
PostPosted: Tue Dec 15, 2015 7:51 am Up
Yeah I thought as much. The axle I am getting comes with the handbrake cables so hoping I don't need to get anything else and the axle itself will actually fit otherwise I will.have to go back to square one with my search!
Sim
PostPosted: Tue Dec 15, 2015 5:54 pm Up
I just asked pro_steve on what exactly needs to match ABS (if there's something more to it than just rings, especially when there's an age difference - yours minor though -- just 1 year, so should be OK), let's hope he replies. It's more concerning for big age differences such as fitting a 2003 GTi disk axle on 1999 HDi
You are more limited by your donor axle choices due to the presence of extra reinforcing links on SW (the other being GTi 180)
EV (roadtripper)
Jag S(crapped)- & X-Type
GTC VXR (sold)
MrWhite
PostPosted: Wed Dec 16, 2015 6:50 am Up
I fit a 2006 Gti axle with 21mm torsion bars on my 51 Plate hdi. the mounting points are the same. the only differences are handbrake cable and abs sensors. Providing the Axle isnt on a CC model where as that uses asr not abs. I used to work in a Peugeot breakers and we reconditioned axles
PostPosted: Wed Dec 16, 2015 7:58 am Up
The rear sway bars can be swapped over to some axles. I know my GTi 138 has the mounting points for them.
Ross74H
PostPosted: Wed Dec 16, 2015 10:07 am Up
Cool, thanks guys, sounds like it should fit physically.
I wasn't sure if it would fit but it sounds like the only real issue will be if the abs sensors are the same.
Once I'm certain the abs sensors are the same I will get it and then I can move on to fixing the next issue.
PostPosted: Wed Dec 16, 2015 2:50 pm Up
Any 206 axle will fit regardless of what car it's come from. It's just the abs & braking system that differs. That and the thickness of the torsion bars & anti-roll bars.
