Online Now [1033]:
Visitors: 1033
Today: 133786
Total: 152532748
Forums › The Car › 206 Talk › Where does this tube go?
Forum Index › 206 Talk
QuArTz
PostPosted: Sat Jan 02, 2016 5:25 pm Up
Trade Rating: +16
Hi.
I'm investigating an issue I have with my Petrol 1.4 2004 206 S
My car idles very lumpy and 'hunts' while stationary, to the point where it will go up to 1500 Rpm, then down to 850 Rpm then back up, almost stalling as it drops.
Now upon investigation, Ive noticed that when I disconnect the plug in (GREEN) there's a lot of air and the car stops hunting and keeps a steady idle, I reconnect and the car starts hunting again, can anyone tell me what might be the problem here..
Also... where does the end of the pipe go in (RED)
I will be getting the codes read in the next couple of days.
cainw1
PostPosted: Sat Jan 02, 2016 5:54 pm Up
there could be a blockage in the pipe, i had a problem with mine where the pipe had melted and sealed itself up so i had to cut and repair it.
Motorracingbruce1980
PostPosted: Mon Jan 04, 2016 3:00 am Up
The green arrow is the breather pipe they do get blocked and collapse.
The red arrow is a fuel line
Project China Blue 206 GTI
PostPosted: Thu Jan 07, 2016 2:58 am Up
As the guys said above,the Green arrow for the breather hose,and the red arrow it might be the return fuel line for the canister valve.
Try to clean the throttle body,and the stepper motor,as it's the majority for idle problems caused by it,when the breather is disconnected from the intake manifold the car get better because it's not sucking air from the camshaft,and the air goes freely.
QuArTz
PostPosted: Fri Jan 08, 2016 5:34 am Up
Trade Rating: +16
Thanks for all the replies guys.
I will hopefully have this looked at this weekend.
I have my assumptions as to what is wrong with the car.
But until I have the codes read, I wont know for sure.
