Latest: DanDan17
Overall: 17128
Online Now [122]:
Visitors: 121
Today: 23604
Total: 100451296
Forums › The Car › 206 Problems › Trip counter changes and electric windows problem
Unicorn
PostPosted: Sat Jan 23, 2016 11:49 am Up
Hi all I have a 206 1.4hdi no abs 52 plate and have a strange problem with the trip counter and was wondering if anyone may have an answer. If I press and hold the right hand button on the dash clocks I reset the counter to zero but after about 40 miles it changes to the last 3 digits of my cars total mileage with the point and tenth of a mile eg 587.4 as i am new to a 206 am I setting the counter correctly or is it a malfunction that can be repaired. On another problem is there a way to set the electric windows to rise lower automatic when holding button for 2secs as my drivers side will do it but the passenger one stops when you take your finger off the button. On my previous car a zafira it was set by holding the switch while the ignition was in acc position but I tried this and didn't work.
Thanks in advance
Chris
PostPosted: Sat Jan 23, 2016 12:10 pm Up
Known BSI software bug.
Live with the fault or take it to a Peugeot main dealer & pay for a BSI software update.
Passenger window needs additional hardware fitting to make it one shot, ive done it with total closure, its not that easy.
Unicorn
PostPosted: Sun Jan 24, 2016 8:37 am Up
Thanks mrbsi I'll live with it I was just wondering if counter was a simple fix I will leave door too just thought it was strange that the drivers door was one shot and passengers was not. I guess must have had a door or motor change at some point
Cheers
Chris
PostPosted: Sun Jan 24, 2016 8:41 am Up
The one shot window components are inside the window switch.
If equipped with a one shot window, a 206 has only ever had one fitted & its only on the drivers window.
Unicorn
PostPosted: Sun Jan 24, 2016 1:41 pm Up
Thanks mrbsi unusual but explains a lot drivers side works one shot
