Online Now [1295]:
Visitors: 1294
Today: 181569
Total: 155271617
Forums › The Car › 206 Problems › Axle Height
Axle Height
yokel
PostPosted: Thu Jan 21, 2016 9:07 am Up
Hi Guys,
Quick question for you. Where do I measure to and from to get the height of the axle? My axle needs to come off and go away to be repaired (under warrenty). If the axle needs to be replaced then I need the axle people to set the height for me, all they need is the measurement. I will ask them but just seeing if any of you chaps know.
Cheers
adran
PostPosted: Sun Jan 24, 2016 5:06 pm Up
HI, if your taking the axle off complete and sending it back for repairing,
ie, (replacing radius bearings), they will do all the settings,
yokel
PostPosted: Mon Jan 25, 2016 1:31 am Up
Hi,
Sadly they don't know the height that its been set to, so when it comes to replacing or fixing they need a height to reference. Apparently they have a jig setup where they can adjust the axle height, all they need to know is this reference height. I have now been informed that the height they require is from the stub pin to the bottom of the boot.
Cheers
adran
PostPosted: Mon Jan 25, 2016 1:53 pm Up
Hi, When i renewed the o/s radius bearings on my axle i measured the distance from the rear plate of the trailing arm up to the underside of the floor which was seven and a half inches, worked fine,
