Online Now [333]:
Visitors: 332
Today: 127727
Total: 154684596
Forums › The Car › 206 Talk › 206 1.6 hdi quicksilver
Forum Index › 206 Talk
More bhp
Budget
66%
 66%  [ 2 ]
Performance
33%
 33%  [ 1 ]
Total Votes : 3
Trebor12013
PostPosted: Thu Feb 04, 2016 4:07 am Up
Hello. I'm trebor. I have 1.6 hdi quicksilver 2005-06. Today I'm having a turbo replacement. Is there a way the improve performance on a bugget Cool
PostPosted: Thu Feb 04, 2016 9:43 am Up
1.6 HDi, bin it before it starts costing you even more money
PostPosted: Thu Feb 04, 2016 11:08 am Up
What He Said
Have a read Wink
www.theturboguy.com/up...es-3-2.pdf
Trebor12013
PostPosted: Thu Feb 04, 2016 2:35 pm Up
Thanks for the replys guys I've had the car over 6 years now and thus is the only major problem I've had. I can't give up on my baby just yet
PostPosted: Wed Feb 10, 2016 12:17 pm Up
Don't give up on your baby,keep it as having a new turbo is like having a new heart,the bad reputation that this engine have because people run the engine without having an oil change,until it's too late,to keep the engine well,it need to have engine flushing,and specific oil used,and run it for low mileage to keep it clean,and no carbon build ups inside the engine.
The most important is to follow the instructions when fitting a new turbo,you need to have an engine flush before you take the old turbo out,then take the old turbo,replace the turbo oil feed,and the oil return pipe,and oil refinery that sucks oil from the oil pan into the oil pump,clean or replace the oil pan if needed.
Then have a new oil filter fitted,and fill it with oil,and run the engine for 15 min. in Idle,turn it off.
Have the oil out,put a new oil filter,and new oil again,and take it for drive.
I will try to get you the full details,but this should be enough :),good luck.
Shadowstalke
PostPosted: Wed Feb 17, 2016 4:59 pm Up
Had mine 5 years. Going strong still on 95k
1.6HDi. Pull like a train. Smokes like one too!
No Smoke, No Poke!
