Posted: Sun Feb 07, 2016 8:29 am |
Does anyone know if you can still buy a gti expansion tank from Peugeot if so does anyone have the product number for the expansion tank in a gti?
Posted: Sun Feb 07, 2016 9:48 am |
got a spare here if u need it
Posted: Sun Feb 07, 2016 10:36 am |
There are two sorts. One where the bottom hose uses a clip to hold it on and the other uses a conventional jubilee clip.
Posted: Sun Feb 07, 2016 11:22 am |
Mine is the one that has the clip and omega pm me
Posted: Mon Feb 08, 2016 2:29 pm |
Anyone?????
Posted: Wed Feb 10, 2016 12:20 pm |
send me your car last 8 digits,and I will send you the part number according to your car.
