Forums › The Car › 206 Problems › No dash. Need advise |
Posted: Wed Mar 02, 2016 1:41 pm |
Hi have searched the Web for days. Maybe cab get some possible help. Long story
I own a Peugeot 206 1.6 1999 when I first got the car mileage and speedo never worked, after checking mot history on Web it's not worked for around 4/5 years. Still got talked into it by wife
Now recently the dash has completely failed no speedo, no revs, no fuel, milage complete blank there was numbers there, no temp.
If I pull hs fuse the needles move. When I turn ignition they do not move. Possible relay ? If so where is it located
Things I have done. Only error code is 0C00. Also no communication to dash.
I have changed bsi,ecu, . Have checked all fuses all ok apart from fuse 4 did blow have replaced not blown since. Checked earth I'm door sills and going to gearbox. Checked plugs on back off dash all seem well. Changed dash for 3 different dashes.
Only thing maybe to try is take out whole fuse box under steering, any idea how to do this ? Please
Other thing when I gave the underside (fuse box) a knock it came back but went off. Now I can not get it to go again
Forgot to say air bag light fuel light and handbrake also do not come on
Thanks for any advise would be appreciated
Posted: Thu Mar 03, 2016 3:21 am |
Well you said that you have replaced the BSI,ECU,....so for your information the fuse box under the steering is called (BSI),so if you changed that before and dash didn't work ,that is a problem can't be fixed I'm afraid,but my suggestion would be the following:
Replace the (Dash,BSI (fuse box under the steering),ECU,and the Engine fuse box also) from a donor car which is tested or you make sure all is well working if the car still runs before you get it,and make sure it's a Pre-Plex not a Mux,(model 2002) is good,this will improve the chance of having it in good condition,then fit it to your car,and everything should work perfectly.
to take the BSI out,you need to unlock the white clips that is holding it from the lower part,when you get the parts everything will get clear.
Good Luck
Posted: Thu Mar 03, 2016 4:44 am |
Hi mate. Thanks for that It is a pre plex. My bsI is held in by a torx screw and a clip you push in to drop it down then there is a fuse box above that. I have not replaced the fuse box is that hard to take out. I'll see if I can get some pics
Posted: Thu Mar 03, 2016 5:14 am |
[img]http:// [/img]
Posted: Tue Mar 22, 2016 3:36 am |
any updates about this problem?did you got it fixed or not?
