Online Now [332]:
Visitors: 331
Today: 46115
Total: 157235898
Project sleeper
Go to page Previous  1, 2, 3 ... 76, 77, 78 ... 85, 86, 87  Next
PostPosted: Sun Mar 13, 2016 1:42 pm Up
Lets hope...emissions are always a concern.
PostPosted: Thu Mar 17, 2016 4:43 pm Up
Passed the MOT and it's now taxed too. Took it out tonight. Put it this way, those changes I made to the inlet length were well worth it. It feels like a little rocket now!
Nic_206
PostPosted: Fri Mar 18, 2016 2:16 pm Up
Glad too see its now in use I can imagine there was a comment or too about just how clean it is underneath
Ford focus st3 daily driver
Team: Red 20v6
PezHdi
PostPosted: Fri Mar 18, 2016 2:23 pm Up
Get some videos up Edward.
Congrats on passing the MOT Smile
EXL Pez
PostPosted: Fri Mar 18, 2016 2:30 pm Up
They did have a close look at what had been done.
Is the gear change in the GTI always notchy and slightly stiff at times? It's been so long since its been driven I've forgotten what it was like. Maybe some new linkages could be needed.
I reckon it goes better now at 4.5k rpm than it did at 6k rpm before.been wondering what a GTI 180 engine with a ported head and my cams would be like. Higher compression and bigger valves with a stronger bottom end could be interesting.
PostPosted: Fri Mar 18, 2016 6:07 pm Up
The gear change is never the best, but generally once the box & oil come up to temperature there is no issues. When was the oil changed last? There quite fussy when it comes to oil & age/spec.
Will you take it anywhere to have the map tweaked at all?
PostPosted: Sat Mar 19, 2016 4:28 am Up
Oil was last done in 2012 which was less than a thousand miles ago.
I would like to get the mapping looked at. It's not perfect especially from cold and occasionally I can hear it spitting through the throttle bodies.
RandomGT
PostPosted: Tue Apr 26, 2016 2:04 am Up
+1
let us all enjoy the sound of it Smile
PostPosted: Tue Apr 26, 2016 11:54 am Up
Will see what I can do.
Sim
PostPosted: Tue Apr 26, 2016 5:14 pm Up
Nom Nom Droolage!
EV (roadtripper)
Jag S(crapped)- & X-Type
GTC VXR (sold)
PostPosted: Sat Sep 10, 2016 5:48 pm Up
Today I finally worked out where to put my big Jenvey sticker...must be the best modification ever!
Nic_206
PostPosted: Thu Sep 15, 2016 5:33 pm Up
Looks amazing as ever mate! We are still waiting on these videos though Wink
Team: Red 20v6
Sim
PostPosted: Thu Sep 15, 2016 10:22 pm Up
What He Said
EV (roadtripper)
GTC VXR (sold)
PostPosted: Wed Oct 05, 2016 4:19 pm Up
Ooh what's this....? Box out of a 2007 Picasso with the 4.76 ratio final drive. Cost me £75 + postage. Peugeot dealers want £500 for the crown wheel and pinion now!
PostPosted: Sat Oct 22, 2016 6:28 am Up
Big strip down is starting this weekend. Gearbox is coming out and then the engine will be removed to change the Cambelt and locate the source of the oil leak that's been there since Ecosse had it apart.
The shorter final drive will be going in the gearbox and I'm going to fit a lightened flywheel too.
Page 77 of 87
