Online Now [3007]:
Visitors: 3006
Today: 155120
Total: 152994914
Forums › The Car › 206 Problems › 206 hdi 1.4 misfire engine
Bluepug1
PostPosted: Thu Mar 17, 2016 3:51 pm Up
When I came home from F1 auto centre to have new tyres fitted. Later at evening my car engine misfire and has new starter motor fitted two month ago nd new bosch battery. I havent use that car much as I have another car as daily. I check engine for air in fuel and pipe leaks and cant find anything.
Could be glow plugs?
Which relay for glowplugs?
my car is 2006 1.4 hdi on 87,000 miles
Robert
PostPosted: Thu Mar 17, 2016 5:23 pm Up
Won't be glow plugs. Explain what's happening. You can't have misfire on a Diesel engine.
Bluepug1
PostPosted: Wed Mar 23, 2016 8:48 am Up
I turn on ignition and engine dint fire up, engine sputter and shaking. I check rear exhaust no blue or black smoke. Battery is new and been jump start and engine still shaking when I turn and hold ignition
I been pump fuel in and still wount start engine. I have look for cut in fuel pipe and cant find any leak.
I has my car for three years and never been like that before.
Sorry my english is not good and I have upload video to show engine splutter.
video:
vid.me/mw7X
Robert
Danpemble
PostPosted: Wed Mar 23, 2016 11:13 am Up
I'd check the pipes on top of the engine. You have to take the air box off. Normally the air box rubs on the fuel lines on these
PostPosted: Wed Mar 23, 2016 11:22 am Up
Air in the fuel lines as mentioned above is usually the first place to look on these engines.
Bluepug1
PostPosted: Wed Mar 23, 2016 12:57 pm Up
Thanks and I will look tomorrow find them.
Robert
Bluepug1
PostPosted: Tue Apr 05, 2016 7:24 am Up
I have removed air filer housing box and look all fuel lines and no sign air leak and my friend have look and removed fuel filter to spill out and put back and prime up fuel, still no luck. I followed all fuel lines to fuel tank still no sign of rupture. what else can go wrong with these?
Rob
Bluepug1
PostPosted: Thu Apr 14, 2016 5:49 am Up
Anyone help?
Sim
PostPosted: Sun Apr 17, 2016 5:35 pm Up
I had "misfire" (but it was more like engine pulsing, pulling pushing, the whole car slightly jumpy/juddery at certain RPM) on 2.0 HDi, also MPG decreased, the fault was temperature sensor at the side of the thermostat. I can't remember the colour, but they change positions/count and colours of them from engine to engine
EV (roadtripper)
Jag S(crapped)- & X-Type
GTC VXR (sold)
Bluepug1
PostPosted: Thu May 26, 2016 11:47 am Up
Cheers, I been look temperate sensor and it wasnt them. Has look by mechanic and found it be camshaft sensor and crank sensor, replaced both of then and new thin pipe to go in top of crankshaft housing and run fine now.
Next time check for camshaft and crank sensor and swap for new sensor to see if it was fauty sensor.
Rob
