Latest: heikkisj
Overall: 17126
Online Now [53]:
Visitors: 52
Today: 20245
Total: 100256530
Forums › The Car › 206 Talk › Lambda/o2 sensor.
Lambda/o2 sensor.
millerman
PostPosted: Sat Mar 19, 2016 12:32 am Up
Hi, car is a 1.4i auto, year 2000, I,m having the complete exhaust changed incl the cat, my question is, how many 02 sensors does my car have, 1 or 2? I will be looking to change the sensors as well so need to know, a hip injury forbids me from getting under the car. If it does have 2 sensors will they both be the same or will 1 be a pre cat and the other a post cat?
Thanks in advance.
If you think no one cares, try missing a mortgage payment!
PostPosted: Sun Mar 20, 2016 10:11 am Up
some cars got 2 sensors,and others got one,as mine in 2006 ,1.4 Auto,and it only got one sensor,so you need to fit what your car got already.
millerman
PostPosted: Sun Mar 20, 2016 1:52 pm Up
Thanks a lot for swift reply fella.
PostPosted: Tue Mar 22, 2016 3:34 am Up
You are most welcome my friend,well for a detailed version of my answer,I would need your car VIN so that I can check what your car got from factory,but you can see both O2 sensors while you are standing looking at the engine bay,as usually the first (upper) O2 sensor is before CAT,as you can see it on top of the manifold,and the second (Lower) O2 sensor is after the CAT right on the first curve in the pipe,it can be see from above,no need to lay down.
millerman
PostPosted: Tue Mar 22, 2016 1:52 pm Up
Thank you for a detailed answer, my cat is not below the manifold, it is under the car, which proves what I was told in that the 206 petrol cars have 2 different locations for the cat.
PostPosted: Wed Mar 23, 2016 9:23 am Up
Well that is checking by the VIN would answer everything,as I can see what you got 100%,unless you already had the job done Smile
millerman
PostPosted: Wed Mar 23, 2016 2:00 pm Up
Ok, VIN is; VF32CKFXP40859775. Thanks for all your help.
PostPosted: Wed Mar 23, 2016 2:21 pm Up
Single lambda sensor in the down pipe for that VIN.
millerman
PostPosted: Thu Mar 24, 2016 12:05 am Up
I love this place, once again you guys have come thru for me, thanks a lot. Very Happy
