Latest: heikkisj
Overall: 17126
Online Now [57]:
Visitors: 56
Today: 1387
Total: 100310819
Forums › The Car › 206 Problems › Help really needed
Help really needed
Mark17
PostPosted: Tue Mar 22, 2016 5:43 pm Up
Bonjourno having trouble with the wife's pug was running fine yesterday then this morning didn't want to start cranks over have taken the cambelt topcover over & the belt is not turning when it cranks over has anybody ever had a similar problem
PostPosted: Tue Mar 22, 2016 6:07 pm Up
If the belts not turning that's not a good sign. Put the car in second and rock the car back and forth. Does the belt move then. Off not likely a knackered tensioner or pulley. Don't keep trying to crank it your proa lay damaging to the valves.
Mark17
PostPosted: Tue Mar 22, 2016 6:30 pm Up
Chances are the valves are lunched then
PostPosted: Tue Mar 22, 2016 7:19 pm Up
Was the alternator turning when you were cranking it over?
If not then could be the starter isn't engaging with the flywheel. If this is the case then try giving the starter a tap with a hammer while someone cranks the car over so it frees off the solenoid.
Mark17
PostPosted: Wed Mar 23, 2016 1:42 am Up
Yes the other belts were moving
PostPosted: Wed Mar 23, 2016 3:20 am Up
What mileage is the car on and when was the belt last replaced?
Which engine is in the car?
Unless your handy with the spanners then it's sounding like a visit to the local garage to have the head removed and further investigation done. I'd be airing on the side of caution and preparing for the worse which would be a valve replacement, possibly easier and cheaper to buy a recon head. This wouldn't solve why the belt isn't turning and could be a number of things adding further complications.
gazza82
PostPosted: Wed Mar 23, 2016 5:36 am Up
Belts probably stripped a section of teeth so it is slipping on the crank gear now rather than being pulled around which is why the engine is turning over but that belt isn't moving ..
But as above that does mean that the valves and pistons have come together .. which is not what you want.
