Latest: Mr-Koekwaus
Overall: 17125
Online Now [389]:
Visitors: 388
Today: 35184
Total: 99420348
Forums › The Car › 206 Problems › Fuses and what effect they have on non-starting
jimsigs
PostPosted: Thu Mar 24, 2016 10:35 am Up
Hello all,
Was wiring up a rear camera from the reversing lights when I accidentally shorted out a wire to the car body. The effect was that the car would not start, plip key would not lock/unlock doors, no headlights, no radio, no wipers, no heater, no safety warning lights. The only thing which worked was side lights, instrument lights & interior light. The fault was found to be a blown fuse.
How the hell did all this lot go down when the culprit fuse was for the
Multifunction display, navigation control unit, boot lighting, audio equipment - 20A fuse number 4.
How can this fuse control all that lot - I'm baffled.
Anyone got any ideas ?
Regards
Jim
DREWDEN
PostPosted: Thu Mar 24, 2016 2:43 pm Up
Have you checked the main fuses.
4, BSI 70Amp
5, BSI 70Amp
7, Ignition Switch Supply 30Amp
206 2ltr Hdi glx 53 plate
gazza82
PostPosted: Fri Mar 25, 2016 1:49 pm Up
And the lesson learned? Disconnect the battery before fiddling with the electrics ... Smile
