Online Now [448]:
Visitors: 447
Today: 154270
Total: 154959303
Forums › The Car › 206 Problems › Car won't start, was fine yesterday
charlene87
PostPosted: Sun Apr 17, 2016 4:46 am Up
Hiya, I've just tried to start my car and it wouldn't fire up. It turns over, all the dash lights are on. It was working fine yesterday so I'm a bit confused as to why it won't start now. It has plenty of petrol also. Any advice on what I can do to get it started again?
Sim
PostPosted: Sun Apr 17, 2016 5:30 pm Up
Easiest is to try with another key in case the chip/immobiliser started to misbehave.
Other troubles can be coil pack, earth strap, fuel pump (or air in the system), ...
EV (roadtripper)
Jag S(crapped)- & X-Type
GTC VXR (sold)
PostPosted: Mon Apr 18, 2016 1:12 am Up
What year is it?
Probably crank shaft sensor though
KingCraigx
PostPosted: Tue Apr 19, 2016 4:15 am Up
I had this issue the other day and it turned out to be a fuse from under the steering wheel which had blew!
But... I have also had my coil packed replaced 3 months ago too from it not starting.
"Tuna, no crust"
PEUGEOT206DR
PostPosted: Fri Apr 22, 2016 9:00 am Up
gas pump fuse?
