Latest: Mr-Koekwaus
Overall: 17125
Online Now [447]:
Visitors: 446
Today: 33530
Total: 99459044
Forums › The Car › 206 Problems › Fitting amplifier power cable through firewall-206SW 1.4HDI
shakur
PostPosted: Sun May 22, 2016 6:34 am Up
Hello there!
I'm trying to fit an amplifier and a subwoofer into my 206 SW. The first problem i came accross was finding a pre-existing rubber grommet to get the amp's positive cable through it. I even took out the battery and some of its casing (as i couldn't unscrew a bolt, probably a nut on the other side of it) but I couldn't find anything I could use. Where should i look for a grommet? Or should I just drill a hole myself?
Thanks in advance,
Shakur
shakur
PostPosted: Mon May 23, 2016 4:06 pm Up
Alright I solved the problem, ran it through the wing near the bonnet, through the grommet in the door.
