Latest: dreyfalon
Overall: 17121
Online Now [212]:
Visitors: 211
Today: 65271
Total: 97745770
Forums › The Car › 206 Talk › Help! Water pump cover?
chrisscousins
PostPosted: Fri Jul 08, 2016 11:42 am Up
Location: Home-Lisburn, Northern Ireland. Uni-Edinburgh
Hi, I've had a slight problem when changing the water pump and snapped the bolt then snapped my drill bit trying to drill it out. Does anyone know the proper name or part number for this part. Or even better have one or know where I can get it. My local scrappy is useless!
[img]http://
[/img]
Take her easy and if she's easy, take her home...
chrisscousins
PostPosted: Fri Jul 08, 2016 3:53 pm Up
Should probably say, car is 1.4 8v 2006 model
gazza82
PostPosted: Fri Jul 08, 2016 4:21 pm Up
Try getting a login on Servicebox .. public.servicebox.peugeot.com/
You can look up part number for free and using your VIN number get the right one ... descriptions might be odd as most are translation from French ..
gazza82
PostPosted: Wed Jul 13, 2016 10:07 am Up
Not sure if the OP will every return but I think this is the part he needs although I'd prefer to check with a VIN code
