Online Now [242]:
Visitors: 241
Today: 71038
Total: 127891118
Forums › The Car › 206 Problems › Dreaded rear axle?
Dreaded rear axle?
David1156
PostPosted: Sat Jul 09, 2016 7:23 pm Up
There's a groaning noise coming from the back of the 206 when braking. It's not heard at low speeds but once you're over 15 mph and you brake, it's heard.
The trailing arm bearings were replaced a few months ago but i'm guessing they were just a quick fix and that the rear axle needs replacing. Can anyone confirm if this is true?
Many thanks
Current: Albi Blue Clio 197
RoweY
PostPosted: Tue Jul 12, 2016 4:49 pm Up
On mine when my back axle went the rear wheels started to camber inwards that much that the tyre touch the wheel arch. Sounds stupid but i would just pull the drum off and have a quick check
