Latest: Mr-Koekwaus
Overall: 17125
Online Now [530]:
Visitors: 529
Today: 38538
Total: 99423702
Forums › The Car › 206 Problems › Driver's door lock faulty - Anything opens it!
Clivey
PostPosted: Fri Jul 15, 2016 1:20 pm Up
Hi all, I have a small problem!
The driver's door lock on my 1999 206 L (non central locking model) has developed a fault in that anything from a screwdriver to the ring pull from a drink can will open it - if you can fit an item into the slot, the lock will turn. Now this is funny...until someone breaks into my car!
Can I repair or replace the lock without having to change them all?
Thanks for any help in advance! Thumb Up
PostPosted: Fri Jul 15, 2016 3:47 pm Up
Peugeot main dealer can supply a replacement lock barrel matched to the original key.
NOTE: It takes up to 2 weeks as the lock barrel is built to order & comes from France.
Peugeot main dealer will ask for your photo ID & proof of car ownership before supplying a lock / key.
Have you tried some lubricant in the lock barrel?
Clivey
PostPosted: Fri Jul 15, 2016 5:18 pm Up
Thanks! I didn't realise they'd supply a matching lock.
I'm not sure I understand your last comment. How would lubricant help? Sorry if that's a stupid question!
1999 'V-reg' 206 1.9D L 3-door
MikeWarr
PostPosted: Mon Jul 18, 2016 7:05 pm Up
spray a bit of WD40 into the lock
the pins might be stuck
But in the door lock obviously
Clivey
PostPosted: Mon Jul 18, 2016 8:43 pm Up
Oh, OK. Thanks! Didn't think it'd be that simple to be honest! I'm used to working on my Land Rover...where a quick "5-minute job" often isn't! Laughing
PostPosted: Tue Jul 19, 2016 8:08 am Up
NO
Do not use WD40 in locks. It is an oil based lubricant. Dirt and dust stick to the oil and that then makes the locks wear even quicker.
Use a PTFE based product. WD40 do one in their specialist range wd40specialist.com/pro.../dry-lube/
It's also worth using this on the fuel cap lock in winter to avoid it freezing. We've not had a frozen fuel cap on here for a couple of years, although the winters haven't been as harsh
Clivey
PostPosted: Wed Jul 20, 2016 9:18 am Up
I've just seen the last reply...too late unfortunately. I already tried it but to no avail. Confused
Should I just visit my local dealer and order a new lock, or have I got a realistic hope of fixing this one?
