Forums › The Car › 206 Problems › Rear Pad retainers/sliders rattling |
Posted: Tue Jul 19, 2016 5:12 pm |
Hi there
Has anyone got any tips on how to stop the sliders/retaining pins on the rear calipers rattling?
If I try and move them they move forwards and backwards fairly easily but the pads are fixed well in position.
Incase I have got the term wrong its the metal bit that goes under the brake pads holding them in position.
Any ideas?
Cheers!
Posted: Tue Jul 19, 2016 7:47 pm |
Have you got little pins holding them in?
Posted: Wed Jul 20, 2016 8:43 am |
Thanks for your reply. Yeah the pins are in. On further inspection the pads actually move up and down a tiny bit when the brakes are off
Posted: Wed Jul 20, 2016 3:08 pm |
What brand of pads are fitted?
Decent ones like Brembo, Ferodo or genuine PSA?
OR
Cheap s**te like Power Train, Drivemaster, EBC?
Posted: Wed Jul 20, 2016 8:02 pm |
The pads should be quite a snug fit. My little wedges need to be lightly tapped into place as there is no free play between pad and wedge.
Posted: Thu Jul 21, 2016 2:22 pm |
Thanks for the message again Edward.
I have figured the problem out there are no anti rattle clips on the rear pads, so I have some coming tomorrow.
The point at which the pad rattles is exactly where the clip goes over the top so it should be gone after they are fitted!
Posted: Thu Jul 21, 2016 6:04 pm |
You talking about the big paper clip type clips? I didn't think they actually did much.
Posted: Thu Jul 21, 2016 6:46 pm |
Yep the big clips. Its weird because my old pads didn't rattle without them, but I can see if there was a clip on top it would stop these ones moving completely. Fingers crossed!
Posted: Sat Jul 23, 2016 3:24 pm |
Fitted the rattle clips today and problem solved! Certainly didn't break the bank
