Latest: sparrowdclxvi
Overall: 17139
Online Now [145]:
Visitors: 144
Today: 39371
Total: 113239266
Forums › The Car › 206 Problems › Help identify this part please!
Muddytoast
PostPosted: Mon Aug 15, 2016 12:35 pm Up
This ring is rattling over bumps, the other side is tight but this one spins and has movement to rattle.
What is it? Any idea on the problem? Its just a passed it's MOT.
postimg.org/image/ib7f.../c4b9baf1/
gpvecchi
PostPosted: Mon Aug 15, 2016 1:40 pm Up
That's an heat shield to protect the gum from brake heat. It should not be so noisy... If you want to raplace it, it's very cheap.
Silver grey RC|Pug Sport remap|Group A induction|Supersprint backbox|lower strut bar|RCCup wishbones|Eibach Pro-Street-S|302mm brakes+23.8 master cylinder|Vibra Technics|Quaife LSD|Cupra R splitter|modded bonnet vent|black Valeos|207i tail lights|Chromed rear foglight|Bi-xenon 6000k+all led (in+out)|406 rear mirror
Muddytoast
PostPosted: Mon Aug 15, 2016 2:31 pm Up
Awesome, thanks for your help Smile
The play is up and down, as shown in this image.
Worth replacing? I assume it's the rubber seal that needs replacing not the heat shield ring as it look as thin on the other side?
postimg.org/image/7nhk...1/59602681
PostPosted: Tue Aug 16, 2016 6:41 pm Up
Probably the ball joint knackered. Not the heat shield
gpvecchi
PostPosted: Tue Aug 16, 2016 6:52 pm Up
I replaced mine because of a tinging sound. If it's more a knock, it's the joint.
Muddytoast
PostPosted: Wed Aug 17, 2016 10:53 am Up
It's not a knocking it is definitely a metallic rattle. Like shaking the washer on and nut.
Wiggling that ring makes the exact same sound, The question is what is allowing the ring to move??
Muddytoast
PostPosted: Wed Aug 17, 2016 12:44 pm Up
If it helps here are a few pictures of both sides
Passenger side = Rattle: postimg.org/gallery/24i47ur0a/
Drivers side = No Rattle: postimg.org/gallery/1dl97pg6y/
PostPosted: Wed Aug 17, 2016 2:30 pm Up
There are little tangs that sit in the gap in the hub to ball joint mount. If the tang is squashed flat it will allow the shield to move about.
gpvecchi
PostPosted: Wed Aug 17, 2016 4:01 pm Up
There's a small piece that fits into yoke groove. If that is consumed, it rattles. Buy a new one it's 1 or 2£.
Muddytoast
PostPosted: Thu Aug 18, 2016 7:04 am Up
Thanks guys! Very much appreciate the help. I'll check + get one ordered
