Posted: Sun Aug 14, 2016 4:40 pm |
Hi,
New to 206's but not new to stripping out engines etc. I am currently trying to replace blown head gasket on 1.4l 206 8v (2003). I have striped out the main drive belt and rocker cover and cam covers. Removed all cables and pipes and now need to fit 10mm and 6mm locking pins to stop any cam movement before I remove the cam belt and head. I could move the engine over when I started but now unable to manually move the engine to TDC even though the spark plugs are out.
Any ideas as to what could be stopping the engine (the engine was working fine, apart from head gasket, before I started so no major reason why it 'locks' in one place). I can jiggle the engine a bit but it jut will not rotate past a certain point.
Any ideas would be very welcome.
Best regards,
Zero.
Posted: Sun Aug 14, 2016 7:58 pm |
The timing is incorrect, or the valve clearances are 10 million miles out
Did you pin it via the flywheel and camshaft?
| Team Impossible Possible
Posted: Mon Aug 15, 2016 6:29 am |
Is the car in gear? Silly question but amazing how many people don't check this when trying to turn an engine by hand.
Posted: Mon Aug 15, 2016 7:58 am |
Macca1411: I did check it was in neutral, but thank you for the hint.
Addaz: I have not been able to pin the two points yet as I am unable to turn the engine to the correct position. The cam belt is still on but not able to move to that final locking position.
Is there a way to remove the cylinder head and reset the timing later?
Best regards,
Zero.
Posted: Mon Aug 15, 2016 11:56 am |
Surely if it's all yet to be stripped apart you just need to make sure all pistons are at the same position I. E. Halfway up the bores and then take the head off? Lock the cam and crank when it's reassembled.
Posted: Mon Aug 15, 2016 12:17 pm |
Edward, I am just being cautious as I do not wish to dismantle and not be able to set up the timing correctly afterwards. Are you aware of a manual timing routine?
Best regards,
Zero.
Posted: Tue Aug 16, 2016 1:24 pm |
Has there been water in the bore?
Is there maybe a rust ridge stopping the piston coming up the bore.
On a different note.... never turn your engine over using the cams.... always the bottom crank pulley.
Posted: Tue Aug 16, 2016 2:07 pm |
ElectronZero wrote: |
There won't be anything to stop you putting it back together and timing it properly later.
Posted: Fri Aug 19, 2016 7:35 pm |
Macj: Not sure if water got in but I could turn the engine when it had spark plugs in but since taking them out I can no longer move the engine around....
Edward: I am unable to find any details of how to set the timing up if the locks are not in position. Can you point me to where I can find details on this (I have the Haynes Manual - but no details there)
Many thanks to you all for taking the time in replying.
Best regards,
Zero
Posted: Sat Aug 20, 2016 9:57 am |
Whip the head off.... the timing is relatively easy once you know what your looking at inside. If you have any issues in the bores you will have to deal with that first.... setting the timing up is a case of matching a diagram of timing points which we can find.
Posted: Sat Aug 20, 2016 1:00 pm |
Macj: Head is off - very messy
I am going to get head skimmed as quite pitted and then rebuild from there. Where can I find details of the timing points or do I just move the engine to the two lock points, lock them and rebuild?
Posted: Sat Aug 20, 2016 2:47 pm |
Don't turn the crank with the head off as you risk disturbing the cylinder liners
Posted: Sat Aug 20, 2016 5:18 pm |
macca1411 wrote: |
Don't turn the crank with the head off as you risk disturbing the cylinder liners |
Correct, you need special locking tools to lock the liners in position if you wish to turn the crank with the head removed.
Posted: Sun Aug 21, 2016 11:05 am |
Thanks for the info. I will proceed with caution. I have a day or so of work just to clean out all the contaminated water from the block before rebuilding.
Posted: Sun Aug 21, 2016 3:33 pm |
You only have to pop a piece of angle iron across the liner tops to stop them from moving but it sounds like a liner moving is the least of your worried... I think if the head is pitted you may need a replacement second hand engine.. . It may be cheaper in the long run
