Online Now [224]:
Visitors: 223
Today: 109349
Total: 128209055
Forums › The Car › Solved 206 Problems › Automatic front lights? - RESOLVED
Go to page Previous  1, 2
PostPosted: Fri Aug 26, 2016 6:35 pm Up
It can be adjusted with Peugeot planet. It's peugeots own diagnostic equipment. You can buy knock offs from eBay. Quite useful to own. You need windows xp for it.
Sounds to me like you have daytime running lights activated on your car. Or the sensor/stalk is faulty. Shouldn't drain the battery though unless they never turn off!
PostPosted: Fri Aug 26, 2016 6:37 pm Up
Auto lights can also be turned off using the method above if it's a problem.
PostPosted: Fri Aug 26, 2016 6:42 pm Up
Planet / Diagbox runs fine on a 32 bit version of Windows 7.
Page 2 of 2
