Latest: dreyfalon
Overall: 17121
Online Now [66]:
Visitors: 65
Today: 14370
Total: 97295476
Forums › The Car › 206 Problems › Drivers seat wont lock into position
Go to page Previous  1, 2, 3
chriskaiflux
PostPosted: Wed Aug 31, 2016 9:47 am Up
So glad I found this thread, about to try this myself, hope it goes okay
panther12
PostPosted: Tue Oct 25, 2016 8:48 am Up
I'm still after a seat slider catch for the passenger side. As a temporary solution to keep the seat from sliding back & forth, if you remove the plastic side skirt panel from the seat you will then see a spring loaded mechanism. If you manually press down the spring loaded mechanism it will lock the seat onto the runner. You can still adjust the seat using the lever at the front of the seat and it will stay locked to the runner until you drop the backrest forward to allow rear passengers.
jess
PostPosted: Thu Nov 03, 2016 10:13 pm Up
Hi I have a problem with both driver and passenger seats not reclining all the way up, any advice
Page 3 of 3
