Latest: S2cgm
Overall: 17178
Online Now [193]:
Visitors: 192
Today: 57027
Total: 136912906
Forums › The Car › Solved 206 Problems › Peugeot 206 track rod end grinding (Solved )Dlte plz )
SkintFlint
PostPosted: Sun Aug 28, 2016 7:31 pm Up
Problem 206 2002 1.1
Tie rack end scrubing wheel on inside
Hi there looking to see which way up driver side and passenger side tie rack end ball joints go .
Do they go down into hole. Or up through it, and is it diffrent at Either. End .
Problem seems to fix if I put ball joint on top it clears the wheel but if it goes up through it rubs .
Any help appreciated
PostPosted: Mon Aug 29, 2016 9:02 am Up
They face upwards with the nut on the top. You are referring the the track rod end aren't you?
SkintFlint
PostPosted: Tue Aug 30, 2016 9:13 am Up
Thanks for reply
yes track rod end ball joints .
If this is the case I.still get some serious rubbing
on the inside of my alloy or standard.steel wheel
Any ideas why this.would be like this .
Only happens on full right lock
Thanks again
macj
PostPosted: Tue Aug 30, 2016 9:43 am Up
Post up a picture to help explain the problem
SkintFlint
PostPosted: Tue Aug 30, 2016 5:46 pm Up
SkintFlint
PostPosted: Tue Aug 30, 2016 5:51 pm Up
Picture of driver side track rod end ball joint grinding alloy
PostPosted: Tue Aug 30, 2016 6:31 pm Up
Track rod ends are handed and are offset to the front or rear - I guess to avoid fouling the wheel, unless the wheels are wider than they should be....trying to find some pictures of mine.
macj
PostPosted: Tue Aug 30, 2016 8:19 pm Up
Looks like the wrong joint. Also can I assume you will put new discs and pads in too
PostPosted: Wed Aug 31, 2016 5:10 am Up
Im sure that threaded part sticks up further than on my car.
SkintFlint
PostPosted: Wed Aug 31, 2016 7:51 am Up
Thanks for replys
About it being wrong one ive been back and fourth to euro car parts now three times
And constantly been given the same ones
I even tried asking them to show me both.but they are nearly identical the ofssets the same
But the.rhs is silver and the lhs is.black
Also tried switching them still get the same problem.
And dont sell.any more than the two I have been giving .
So im left thinking possible dodgy batch or something
And the one I took off is diffrent but ive tried several parts shops
And cant seem to find one like the original that came off it.
Brakes. Will.be done beenn.off road for a year now
Thaanks again
SkintFlint
PostPosted: Wed Aug 31, 2016 10:28 am Up
Problem solved travelled. Further afield and got a delphi part that fits fine
First time ive been stunng by euro car parts thanks. Again
