Latest: sparrowdclxvi
Overall: 17139
Online Now [114]:
Visitors: 113
Today: 29951
Total: 113331909
Forums › The Car › 206 Talk › GTI 180 ARB Thickness
RoweY
PostPosted: Wed Aug 31, 2016 6:25 pm Up
Just a quick question really, I'm starting to polybush my GTI 180 and have the choice of 20mm arb bushes and 22mm arb bushes, does anyone know off the top of their head what the thickness of my arb is ?
PostPosted: Thu Sep 01, 2016 5:33 am Up
I thought the front ARB on the 180 was 21mm. 1mm narrower than the rear.
PostPosted: Thu Sep 01, 2016 7:16 am Up
The arb on a 180 is 21mm
RoweY
PostPosted: Thu Sep 01, 2016 3:54 pm Up
Oh Powerflex only list 20 or 22, Cheers for the info
PostPosted: Thu Sep 01, 2016 7:12 pm Up
Not worth changing the bushes anyway.
Sofa.King.Happy
PostPosted: Fri Sep 02, 2016 9:03 am Up
Why doesnt it worth changing bushes to polyurethane? Because I was about to.
PostPosted: Fri Sep 02, 2016 9:45 am Up
Because unless the old ones are knackered the difference will be immeasurable. They will make a microscopic difference to roll levels.
gazza82
PostPosted: Fri Sep 02, 2016 3:48 pm Up
But they might stop it clonking!
