Posted: Mon Sep 12, 2016 12:14 pm |
| Current project: Ciri
Silver 206cc - 2.0 - 2001 | |
Posted: Mon Sep 12, 2016 6:37 pm |
Look on Peugeot Service Box to see which one of the two different front brake options your car rolled out the factory.
The pads required will correspond to the discs.
The rear discs & pads are the same across the 206 range.
Posted: Mon Sep 12, 2016 7:10 pm |
MrBSI wrote: |
The rear discs & pads are the same across the 206 range. | Cheers!
Anyone got access to it? I got my VIN.
Posted: Mon Sep 12, 2016 8:49 pm |
Shoot me your VIN over PM, we'll see.
Also cross-check with brakesint.com -- they have detailed diagrams too for everyday pads; so you can know your dimensions and visual appearance of pads and clips for good.
Posted: Tue Sep 13, 2016 4:55 am |
Sim wrote: |
Also cross-check with brakesint.com -- they have detailed diagrams too for everyday pads; so you can know your dimensions and visual appearance of pads and clips for good. | Cheers!
Posted: Tue Sep 13, 2016 5:13 am |
I'm pretty confident any CC will have the thicker discs.
Posted: Tue Sep 13, 2016 7:55 am |
Sim wrote: |
Also cross-check with brakesint.com -- they have detailed diagrams too for everyday pads; so you can know your dimensions and visual appearance of pads and clips for good. | Hey Sim,
Nevermind! Can disregard the message... I just remembered that I have a company myself. So I registered for the Box
Edward wrote: |
I'm pretty confident any CC will have the thicker discs. | As often, you are 100% right Edward. Double checked them.
OEM: 00004246W7
Posted: Tue Sep 13, 2016 7:56 am |
Edward wrote: |
Looks like on 2.0 CC they replaced 20.4mm ones with 22mm thicker ones from RPO 09079 onward.
"You're pads, Sir":
The rear (as MrBSI said, no differences there):
Posted: Tue Sep 13, 2016 8:26 am |
How would I know the RPO?!
I am quite a novice with this tool (service box).
Big question is: will thicker fit in either way?
Posted: Tue Sep 13, 2016 8:45 am |
RPO number is on the white information sticker stuck on the B pillar OR Service Box lists it under characteristics.
What I got so far... If anyone could
Front Discs:
Thickness of 22mm:
- www.bremboparts.com/eu...09-8695-75
- Based on part number: 4249G1 (superseding 4246W7, 20.5mm)
Front Pads:
- www.bremboparts.com/eu...d/P_61_066
- Based on part number: 425276
Rear Discs:
- www.bremboparts.com/eu...08-5334-75
- Based on part number: 4246G6
Rear Pads:
- www.bremboparts.com/eu...d/P_61_032
- Based on part number: 425271
Pad fitting kit:
- www.bremboparts.com/eu...y/A_02_215
- Not sure if this is needed, I can always return it to our friends at Amazon...
Going to order them soon, as my dad is over in the country 2nd weekend of October, so we can fit everything nicely with the help of a mechanic. Reason I wanted to get the pad fitting kit, whilst it is unlikely I need it, is that I do not want to be in the situation where I cannot fit the pads with my dad because I didn't want the hassle of returning this.
Thanks for all your help! Hopefully the 22mm front discs will fit
Posted: Tue Sep 13, 2016 8:47 am |
MrBSI wrote: |
RPO number is on the white information sticker stuck on the B pillar OR Service Box lists it under characteristics. | Thank you Mr. BSI!
Found it, exactly where you said... and I got 09083... So should be all good!
Hoozah!
More things I should know about the Service Box?
Posted: Tue Sep 13, 2016 9:01 am |
If you got your VIN, it already has the RPO within; so servicebox select the right set. If you choose vehicle specs manually instead, you'll be presented with all options by RPO ranges throughout its making.
I never used pads fitting kit, probably would've saved me a bit of wrestle; but if you're changing rear disks, you'll need caliper winding tool.
Posted: Tue Sep 13, 2016 9:11 am |
Sim wrote: |
I never used pads fitting kit, probably would've saved me a bit of wrestle; but if you're changing rear disks, you'll need caliper winding tool. | Got the winding tool already. Also getting a torque wrench and whatnot.
May as well bleed the system with my dad and redo the fluid...
Posted: Tue Sep 13, 2016 4:20 pm |
Wind back tool doesn't work on 206 rear calipers. Just use a fat screwdriver.
