Online Now [431]:
Visitors: 430
Today: 103855
Total: 155583797
Forums › The Car › 206 Problems › 2005 Peugeot 206 1.4L battery cut out when driving
Nickolii
PostPosted: Thu Oct 20, 2016 8:13 am Up
Hi,
I have an issue where my car cuts out when driving, this is more likely to happen at the beginning of a journey when the car has just been started.
However one time this happened on the dual carriageway at 50MPH 10 minutes into a journey, but quickly the car came back to life.
Any advice please? I have checked the battery and the connections seem fine...
Cheers,
Nick
PostPosted: Thu Oct 20, 2016 9:42 am Up
Well according to what you said,the problem with the car stalls while driving,and then come back to life quickly,then it got nothing to do with the battery,as if it was a battery problem.
But it would be better if you can get it diagnose it with PP2000 for fault codes,as this will make things easier,but for now,the only thing I can think of is that you have a faulty throttle body,or fuel pump.
