Online Now [199]:
Visitors: 198
Today: 164217
Total: 154968173
Forums › The Car › 206 Talk › Transplant - ECU - Pre-plex and Mux
Forum Index › 206 Talk
pAvax
PostPosted: Tue Oct 25, 2016 9:22 am Up
As I have a bad subframe (needs replacement), I am looking at options to get my car in the best shape possible again. That is either getting a new subframe welded on or to get a spares/repairs CC and transplant my stuff.
On the latter I have a question!
If I were to move my engine, 2001 pre-plex, into a newer car and want to take my ECU with it... will it work? Will the BSI or anything else throw a strop, or can I just move the engine, gearbox, my stuff and ECU over without too much hassle?
Are there any crucial things I should consider while doing this? Any help/info is more than welcome!
Current project: Ciri
Silver 206cc - 2.0 - 2001
PostPosted: Tue Oct 25, 2016 9:56 am Up
Engines haven't really changed much....so as long as the engine is going into a car that already had that engine (I. E 2.0 to 2.0) it won't be a problem.
Subframes aren't welded in either.
pAvax
PostPosted: Tue Oct 25, 2016 10:03 am Up
Thank you. Yeah, I'd swap it for a 2.0. And I knew that the engines changed little, but I got a nice remap (lovely torque it gives out!) which I would not want to lose.
As for the subframe, I thought they were point welded on?
Well the main part of the frame is slightly bent (steering is not affected, wheels are spot on), the dent is pretty nasty and I notice it when fitting the fan casing and I can't get the front and side nicely aligned.
Here a pic...
PostPosted: Tue Oct 25, 2016 11:06 am Up
You won't be able to move the ecu I imagine. I'd just get another remap.
Subframe is just 4 bolts to the body. Two for the steering rack and one for gear linkage, one for rear engine mount and PAS pipe bracket.
Can you not get a repair piece to weld on place of that bent bit?
pAvax
PostPosted: Tue Oct 25, 2016 11:43 am Up
Might be the best option yes.
I cannot weld myself, but I have a body/repair/workshop not too far away from me. I will try and see if I can get this piece and have it replaced.
In fairness, I rather not give up on this car and make it as good as possible... instead of dropping out and doing a transplant. Feels like giving up early!
The top bit, where the bumper bar sits can be hammered smooth, that is not an issue... and then I should be able to get a lower subframe yes.
Just checking Servicebox, it appears they call it a part of the 'cant rail'.
Perhaps I should get it crudely taken away at a breakers and take it home for prepping and contact the shop indeed. Potentially they can help me getting everything straight again too, should be lovely.
Ugh, wish my daily didn't have a problem (blasted Ford Focus with their bonnet issues!), else would have taken this car apart now and got things done for the winter. Hoping to get it tip-top come spring so I can continue improving it before potentially enhancing the power further (read: throwing money at it).
PostPosted: Tue Oct 25, 2016 3:00 pm Up
The bent part in your picture is the chassis leg, its designed to deform in a front on accident.
Check the rest of the front end is straight then have the bent one replaced for a proper job.
As for your Ford Focus, I take it you have a faulty lock barrel & bonnet catch? Repair kits are available on everyone's favourite online auction site - its a very common problem.
pAvax
PostPosted: Wed Oct 26, 2016 9:11 am Up
Yes, and I am not going to give it up on it. So will be replaced... Will swing by a workshop over the weekend to see costs etc.
The rest is rather straight, other than needing some pushing and pulling in places. I do wonder what happened with the previous owners!
Yep, but I don't have too much time. It is dark when I get home from work etc. The grill is off (in pieces :() and the car is on ramps... In the weekend I am going to squeeze my hand in to open the b*****d... and then order again what I need to replace. Great idea by Ford, shyte execution as usual.
I have decided to replace the part (as said before) and to make a new housing for my fan as well - using aluminium or something. Just to make it tidier and to expose my fan a bit more (large parts are hidden by that silly plastic). Just to keep me busy and as part of the rebuilt of the front Smile
gazza82
PostPosted: Thu Oct 27, 2016 11:53 am Up
That "silly plastic" is the fan shroud and will help the airflow through the rad .. you may find it isnt half as efficient with it missing as the air will blow out the sides!
gazza82
PostPosted: Thu Oct 27, 2016 11:54 am Up
You aren't going to be able to use a pre-mux ecu in a MUX car ... wiring looms will be completely different!
pAvax
PostPosted: Thu Oct 27, 2016 12:01 pm Up
Yeah, I see now the wording is wrong!
I was going to stay pre-mux... but with newer car I meant a later date of purchase. I want to stay pre-mux!
Sorry for that.
So would have been 51 plate to 51 plate without damaged frame.
pAvax
PostPosted: Thu Oct 27, 2016 12:08 pm Up
Yep, I see what you mean (concentrating air to the center of the radiator) -and ensuring that the fan directs the air inwards/towards the radiator instead of around.
However there should be more elegant solutions... But will see, first the necessary items such as ensuring that the frame has a new lower leg.
PostPosted: Thu Oct 27, 2016 3:31 pm Up
I'm pretty sure Peugeot will have spent a fortune on R&D and will have already come up with the best design through testing. By removing some of the airflow around the radiator could cause further problems as the heat in the engine bay will increase. I'd stick with the tried and tested design.
Sim
PostPosted: Thu Oct 27, 2016 8:02 pm Up
My thoughts exactly after the pugpicker thread comment about front grilles, it's most important to cool the engine from within (rad), than just having airflow on it's outside (some heat does dissipate when that huge HDi 2.0 engine cover goes to bin:) Many people also do away with bottom engine covers
But back at the bumper grille efficiency: does it mean SP mesh compromises the cooling? Surprised (smells like a new topic is in order:) )
EV (roadtripper)
Jag S(crapped)- & X-Type
GTC VXR (sold)
pAvax
PostPosted: Thu Oct 27, 2016 8:42 pm Up
For discussion sake... would Peugeot not look for the balance between easy to maintain, assemble and as cheap as possible to make? Which would mean making compromises... Thus there could be scope for a better solution which would not be profitable to do for a manufacturer (for mass production) but would be for me?
This nicely illustrates your point earlier by the way:
