Online Now [279]:
Visitors: 278
Today: 135185
Total: 155090056
Forums › The Car › 206 Problems › Is my fan deceased?
Is my fan deceased?
BradyBunch
PostPosted: Sat Oct 29, 2016 10:09 pm Up
Hi guys, pug 206 GTI 138 year 2000.
Had the car running at idle today whilst parked, had bonnet up and was just poking around the engine. After a while the engine temp gauge (under the rev counter. Assuming the other temp gauge to the far right is the oil temp) rose just above 90. The radiator fan still hadn't kicked it. Is this normal?
Cheers
PostPosted: Sun Oct 30, 2016 8:21 am Up
Unplug the coolant sensor. If the fan stays off you have a problem. It's more likely to be the wiring to the relays.
BradyBunch
PostPosted: Sun Oct 30, 2016 4:22 pm Up
Cheers Ed, Will have a look!
BradyBunch
PostPosted: Sun Oct 30, 2016 4:27 pm Up
Just remind we where the coolant sensor is? It's a green plug right?
PostPosted: Sun Oct 30, 2016 5:08 pm Up
Green one on the right hand side if the engine block.
