Latest: DanDan17
Overall: 17128
Online Now [67]:
Visitors: 66
Today: 27005
Total: 100454688
Forums › The Car › 206 Problems › Car pulling left after coilover
gpvecchi
PostPosted: Fri Nov 04, 2016 7:24 pm Up
Any advice on this, please?
It happens after coilover install, just under acceleration; angles have been checked...
Silver grey RC|Pug Sport remap|Group A induction|Supersprint backbox|lower strut bar|RCCup wishbones|Eibach Pro-Street-S|302mm brakes+23.8 master cylinder|Vibra Technics|Quaife LSD|Cupra R splitter|modded bonnet vent|black Valeos|207i tail lights|Chromed rear foglight|Bi-xenon 6000k+all led (in+out)|406 rear mirror
Sim
PostPosted: Fri Nov 04, 2016 10:36 pm Up
Check if your coilovers are adjusted equally for damping/rebound and height and are otherwise in good working order
This thread pretty much sums it up all corner cases and what not Smile www.206info.co.uk/Foru...89655.html
EV
Jag S(crapped)- & X-Type
GTC VXR (sold)
gpvecchi
PostPosted: Sat Nov 05, 2016 12:32 pm Up
Lower arms are the major culprit in this cases, but mine are new and genuine...
Sim
PostPosted: Sat Nov 05, 2016 12:39 pm Up
In my case they were also newly fitted wishbones, I was sure they were fine, so went checking through all other possibilities that might contribute to the pulling.
If your ones are genuine, that list is still useful to find the real culprit.
It's all about forces that come in effect when torque is applied to the relevant suspension components, and the extent of that relevance.
EV
GTC VXR (sold)
gpvecchi
PostPosted: Sat Nov 05, 2016 12:59 pm Up
I never heard of wishbones consumption, what's the thing to check?
Sim
PostPosted: Sat Nov 05, 2016 1:04 pm Up
The two bushes of each wishbone that mount inside subframe.
Use a prybar to gently bend a wishbone up or down (when car is jacked up they are opening up nicely already on standard suspension height).
Check for tearing and general condition of rubber behind the metal ring (I assume you have the GTi wishbones)
EV
GTC VXR (sold)
gpvecchi
PostPosted: Sun Nov 06, 2016 1:18 pm Up
Thanks, sorry, my fault. I thought that "wishbones" were swivel pins, not lower arms (that are new)... My fault in translation... Very Happy
gazza82
PostPosted: Wed Nov 09, 2016 4:01 pm Up
Check you have the GTI arms. If they have fitted standard arms the bushes will fail very quickly .. as will cheap, low quality arms.
gpvecchi
PostPosted: Wed Nov 09, 2016 7:39 pm Up
Thanks, they are the GTi ones; but in effects I replaced a lot of them because of the GTi jointball...
Never had any issue with 1.6 gummy bushes.
