Posted: Fri Nov 11, 2016 6:34 am |
Hi guys, as I turn full lock to the right whilst moving (forwards or backwards) I get a loud clunk from the front right wheel area. Occasionally I get the same issue turning left but primarily it's when I throw alot of right steer on and it is getting worse.
206 GTI 138, 100K. Passed MOT last month.......
Cheers
Josh
Posted: Fri Nov 11, 2016 8:07 am |
Top mount strut bearing if doesn't clunk when over potholes, otherwise it will simply be drop link. ask someone else to turn and put your ear over top mount plastic.
I found it was droplink once, I saw&felt its balljoint pop about in socket. Someone turn wheels and you observe the droplink. If get no visual movement, grab a hold of it during the clunk but mind your arms!
Other way is to draw a metal bar from various suspension parts and your earlobe and stethoscope your way through
Posted: Fri Nov 11, 2016 4:20 pm |
Could be the driveshaft joint .. they tend to be noisier when turning.
