Online Now [692]:
Visitors: 692
Today: 137429
Total: 155092138
Forums › The Car › 206 Talk › 206 1.6 16V 2006 - Gearbox Oil Change - Washer/seal size?
Forum Index › 206 Talk
wikpeu
PostPosted: Fri Nov 11, 2016 8:07 am Up
Hi!
I have a Peugeot 206 1.6 16V year 2006 (manufactured in December of '05) that I'm planning on changing the gearbox oil on.
I've already ordered the gearbox oil, 2 liters of Total Transmission Gear 8 75W80 (apparently it's the replacement for the BV).
I'm pretty sure I have the MA5 gearbox (VIN is VF32JNFUA44952326 if anyone's able to confirm).
According to my Haynes "Owners Workshop Manual" the seals/washers on both the drain plug and fill plug need to be changed, but it doesn't state what size the seals/washers are.
Does anyone have a clue what size they are?
Thanks,
Wik
PostPosted: Fri Nov 11, 2016 8:56 am Up
016430 16x22-2 Non asbestos seal £1.82 each from Peugeot
Both filler and drain plug have the same size seal.
wikpeu
PostPosted: Fri Nov 11, 2016 9:08 am Up
Perfect! Thanks a lot!
