Online Now [663]:
Visitors: 661
Bots: 2
Today: 158057
Total: 154539425
Forums › The Car › 206 Problems › Car wont start after stereo install pls help
206help
PostPosted: Sat Nov 19, 2016 6:44 pm Up
hi everyone, im hoping someone will be able to help me, my car has been running fine no issues at all, i got a new stereo (aftermarket) i didn't have the correct wires so i did a bodge job and use the old stereo connector i copied the wire colours so i thought, anyway ive just been outside ive started the car its started ok, iv plugged the stereo in and it turned on had sound everything, then turned the car off , then when trying to restart the car there's nothing, my engine warning light shows and the ( ! ) sign , so i unplugged the stereo and still wont start can anyone help me pls
PostPosted: Sat Nov 19, 2016 6:51 pm Up
Blown fuse in the cabin fuse box.
One of the fuses that protects the radio also protects the immobiliser.
Very common issue when people fit aftermarket radios & don't use a Peugeot ISO plug & play adaptor harness ( which is cheap from any Peugeot main dealer parts department )
206help
PostPosted: Sat Nov 19, 2016 9:40 pm Up
hi do you mean the fuse box under the stearing wheel?
PostPosted: Sun Nov 20, 2016 8:22 am Up
Yes
206help
PostPosted: Sun Nov 20, 2016 12:37 pm Up
think ive found the fuse Smile just need to get a new fuse to try it
206help
PostPosted: Sun Nov 20, 2016 7:59 pm Up
the fuse i found broke is a red 10 a fuse its apparently for the Coolant level – Audio system , would this stop the car from starting?
PostPosted: Sun Nov 20, 2016 8:08 pm Up
Change it and see
206help
PostPosted: Sun Nov 20, 2016 9:42 pm Up
Steve206 wrote:
Change it and see
i would if i had a spare fuse lol got to wait till the morning to go get one, just wanted to know for future ref
206help
PostPosted: Tue Nov 22, 2016 12:02 pm Up
fixed Smile
pAvax
PostPosted: Tue Nov 22, 2016 1:18 pm Up
Good, it was the fuse I take?
Current project: Ciri
Silver 206cc - 2.0 - 2001
206help
PostPosted: Tue Nov 22, 2016 2:19 pm Up
yes was fuse number 6 (red 10 amp) audio and coolant fuse. and now i have an after market stereo i need help fitting, as you cant buy a lead for it
PostPosted: Tue Nov 22, 2016 4:18 pm Up
Peugeot main dealer parts department should be able to get you a plug & play adaptor harness.
206help
PostPosted: Tue Nov 22, 2016 7:06 pm Up
no they cant.
PostPosted: Tue Nov 22, 2016 8:19 pm Up
I'd try a Citroen dealer instead then. It's not a part that's unique to the 206 so I'm very surprised the Peugeot dealer didn't want to supply one, unless you asked for the wrong item.
206help
PostPosted: Wed Nov 23, 2016 3:22 am Up
mate i have an unbranded aftermarket Chinese radio player , Peugeot don't make leads for them and im sure Citroen wont either, il try asking for help on another forum.
