Latest: DanDan17
Overall: 17128
Online Now [63]:
Visitors: 61
Members: 1
Today: 17699
Total: 100445401
Forums › The Car › 206 Problems › Stereo memory problem (206 2.0 HDI Turbo Diesel 01) (SOLVED)
GhostZ
PostPosted: Wed Nov 30, 2016 10:26 am Up
Hey Guys,
I know there are many stereo topics on here and I have had a look through them and nothing has solved the problem. This has been a problem for a while and I have now given up in trying to work out what the problem is. I hope you can help!
Usual problem, every time I turn off the engine the stereo resets its self losing all settings, stations etc... I guess it's just that it doesn't have constant power... problem is which cable is it!
Who ever had the car before me seems to have butchered round back and I'm left with the aftermath. So if someone could please help me!!!
Images below, please help!
I have already tried switching red and yellow.
And then theirs these....
All help appreciated Very Happy
gazza82
PostPosted: Wed Nov 30, 2016 11:58 am Up
That adapter looks like the one we got with our Sony head so it hasn't been butchered .. it comes like that.
You are going to have to break out the multimeter to find out which wires are perm live and which are switched. But all we did was switch red & yellow in that adapter block.
GhostZ
PostPosted: Wed Nov 30, 2016 12:34 pm Up
The adaptor is new, I meant the cables from the last picture. I cant seem to find where they go or what they should have been connected too. But they was cut for some reason.
I have tried swapping red & yellow but I didnt have any look. Very strange Sad Thanks though Smile
gazza82
PostPosted: Wed Nov 30, 2016 3:41 pm Up
Might be for the remote stalk .. check for power.
Shame people do that .. 99/100 is is totally necessary.
mtempsch
PostPosted: Wed Nov 30, 2016 6:30 pm Up
Aftermarket HU's and many cars typically have switched and constant on pins 4 and 7 (though which is which varies, thus the connectors on the red & yellow wires on the HU Harness so it's easy to change them over.
According to my handbook, my multiplexed 206 has constant power on pin 7 and switched (not direct key but BSI controlled so comes on as you unlock and remains a bit after you turn off the car) on pin 6. Ground on pin 8.
Peugeot sells an adapter that transforms the car's ISO block into a more 'standard' ISO block layout, as well as isolates the wires of the messaging bus from the aftermarket HU.
Silvermetallic 2004 206 RC
GhostZ
PostPosted: Wed Nov 30, 2016 7:36 pm Up
I have been reading up and apparently If you swap F24A to F24B on the fuse box this can sometimes resolve the problem. My car is pre-plexed and I am struggling to find any key information. All the threads on here are from years back and the images showing what to do are all broken links now. Any ideas which fuse F24A is?
mtempsch
PostPosted: Wed Nov 30, 2016 9:34 pm Up
A/B is just a matter of shifting it 'a half position' up/down
There should be numbers cast in the plastic at the fuse positions, which can be faintly seen in this pic or this one (a little clearer) if one zooms in...
Looks like 24 is he blue 15A fuse spanning row 2 and row 3 in the pics
GhostZ
PostPosted: Wed Nov 30, 2016 9:52 pm Up
I really appreciate the help, thank you! Smile
Did you mean this fuse? So would I just take it out and try it on row 2 or 3 and see which works?
I have a look in the morning and see if I can see it.
mtempsch
PostPosted: Thu Dec 01, 2016 2:50 pm Up
Yup, that's the one I believe it is. I believe it's shown in the 'alternate' position, with normal position being in row 3 - but check for the numbers in the plastic...
GhostZ
PostPosted: Sat Dec 03, 2016 7:59 pm Up
Hey mtempsch! I managed to get it working thanks to your help. Very Happy I greatly appreciate it! It was the fuse, I moved it over to F24B position and powered it. Still the same... So I swapped the red and yellow over and ay presto!!!
