Posted: Thu Dec 01, 2016 5:39 pm |
So after replacing my water pump pipe due to a hole, the oil breather pipe disintigrated. I bought another, went to remove the old one and instead of just unclipping it snapped off as shown.
Is there a simple cheap fix to this or do i have to buy a whole new throttle housing to replace this one connector? Its getting to the point where im gonna fix this car with some petrol and match if silly things keep breaking!
Posted: Thu Dec 01, 2016 6:06 pm |
I've got a very clean throttle body if you want it. It hasn't been used for 7 years!
Posted: Thu Dec 01, 2016 11:01 pm |
Am i really gonna need a full body transplant just for that one broken piece of plastic!?
Posted: Fri Dec 02, 2016 8:57 am |
Nope. But for £10 you can have my whole throttle body and you can remove the plastic from it.
It's held on with 3 torx bolts I think.
Posted: Fri Dec 02, 2016 9:55 am |
Whilst that sounds like a great offer i kinda need the plastic thingy like yesterday. Do you know if its only on the 138 throttle or the same on any other 206? Gonna have to pop out the scrappy. Also if i gotta whip this out anyway is it worth an upgrade or are throttle bodies always an expensive addition?
Posted: Fri Dec 02, 2016 10:54 am |
You'll probably find no scrappy will sell just part of the TB. You'll need £2k for throttle bodies
Posted: Mon Dec 05, 2016 10:15 am |
10 quid for a TB? That is an absolute steal.
And ugh, my breather pipe snapped too, old and greasy plastic... in combination with freezing temperatures make them very 'snappy'.
| Current project: Ciri
Silver 206cc - 2.0 - 2001 | |
