Latest: ArtistKS
Overall: 17145
Online Now [70]:
Visitors: 69
Today: 21074
Total: 115894054
Forums › The Car › 206 Problems › 206 gti 2.0 faults & loss of power
noddytheblue
PostPosted: Wed Dec 28, 2016 11:29 pm Up
Hi....hopeing you can help me...my 206 gti has always been reliable and never had a problem but today on way home from work i had a engine management light start bleeping and then a loss of power then i had cat converter fault come up then pollution fault...i managed to get home on loss of power and turned it off.....i tried it a few hours later and it was fine but light was still on.....can anybody help or give me any pointers before i take it to the garage....thank you.....
PostPosted: Thu Dec 29, 2016 7:56 am Up
Read the fault codes that are now stored in the ecu memory as the codes will point you in the general direction of the fault.
iancav6
PostPosted: Fri Dec 30, 2016 6:14 pm Up
My missus's gti has done this twice in the last couple of weeks,usually after several days of not running.Starts up ok but quickly begins to chug and misfire as if the choke is on.
Warning for cat fault comes up and ecu light.
I have a cheapo code reader and it reports "random cylinder misfire" can't recall the actual fault no.I clear the fault code and it runs fine,until the next time.
I'm going to replace the coolant temp sensor as a start point.
Buy yourself an OBD 2 reader off ebay,can be less than £15.Doddle to use and you can save a packet of £.in garage charges.
xx
gazza82
PostPosted: Fri Dec 30, 2016 7:29 pm Up
Half the time cheap obd2 readers don't actually give the actual reason because the 206 didn't have obd2 diagnostics. Early ones were a peugeot hybrid and later EOBD.
A peugeot compatible one would probably tell you exactly which cylinder is misfiring ... but it is likely it's the coil pack from the symptoms.
