Forums › The Car › 206 Problems › Do hatchback doors fit sw |
Posted: Fri Jan 06, 2017 8:25 am |
Hi Guys, after an accident I need to replace both drivers side doors on my 206 sw. Do the doors from a hatchback fit. Thanks
Posted: Fri Jan 06, 2017 8:44 am |
Front will from a 5 door. Rears won't.
Posted: Fri Jan 06, 2017 2:09 pm |
