Forums › Tuning, Modification & Legal › Project Cars › Project sleeper |
Posted: Mon Dec 05, 2016 10:16 am |
Edward wrote: |
| Piece of art, that is.
| Current project: Ciri
Silver 206cc - 2.0 - 2001 | |
Posted: Fri Dec 23, 2016 7:13 pm |
206 is back on the road now. The final drive change makes it feel like the engine has a useful mid range now. It's much more usable and the engine can show its power without doing silly speeds. The tall gearing before only allowed the high rev power to show. It's on the edge of traction in 2nd gear now.
I'm not convinced the new flywheel was worth the expense but it won't slow things down.
Next step is a remap. It's a bit spluttery at low revs and so it definitely needs a tidy up.
Posted: Fri Dec 23, 2016 7:23 pm |
Well done just in time for Xmas! What's your next challenge Edward?
Posted: Fri Dec 23, 2016 7:39 pm |
Well after the remap I might eventually look at building a high compression bottom end with forged rods and pistons. That will allow for a higher rev limit...that will need another remap! Might look at oil coolers soon. So that will come first.
Posted: Sat Jan 21, 2017 7:19 pm |
Hard to believe the car is 16 years old now and I've owned it for nearly 14 years. Time flies!
Posted: Sat Jan 21, 2017 7:25 pm |
Posted: Sat Jan 21, 2017 7:26 pm |
Posted: Sat Jan 21, 2017 7:36 pm |
I love the standard OEM look
Posted: Sat Jan 21, 2017 7:45 pm |
Reckon wheels like on Jeremy's Maserati would suit a 206? I've always liked them. They look like O.Z Rallyes to me.
Posted: Sat Jan 21, 2017 8:27 pm |
this thing is so clean, reminds me of my old moonstone, the one you kept saying about a private plate lol
these might look alright on yours
www.wheelbasealloys.co...oC-0Dw_wcB
Posted: Sat Jan 21, 2017 8:38 pm |
Yeah they look ok. Years ago they also did Sparco Chromadora wheels and they looked good.
Posted: Sat Jan 21, 2017 8:44 pm |
considered these for my 180 but ended up buying td pro race 1.2's in anthracite which I never got round to fitting
Posted: Sat Jan 21, 2017 9:39 pm |
Posted: Sun Jan 22, 2017 11:00 am |
These are similar but I think they only do 16" max.
