Online Now [65]:
Visitors: 64
Today: 70663
Total: 116806764
Forums › The Car › 206 Problems › 2003 1.4i 8v cylinder head bolt torque problem
bill555
PostPosted: Mon Feb 27, 2017 10:03 am Up
Hi guys,
Just changed the head gasket on my wife's 206, it's a 1.4i 8v. Problem has been a long term oil leak from the front of the head and more recently water in No.1 cylinder (gearbox end). Torqued all the headbolts in sequence to 20nm, then +240deg in the same sequence. Everything went well except for the last headbolt which got to about 140deg and would not go further without what I believe would have been destructive force accompanied by lots of extreme noise and judder. Anyway my problem is where do I go from here? Do I leave it alone? Do I remove the bolt and try again? If so to what torque and angle? The head is pretty much pulled down so different start position now. Perhaps I'm worrying too much.
Any advice, ideas or comments would be appreciated.
Bill.
PostPosted: Mon Feb 27, 2017 12:38 pm Up
Are they NEW virgin head bolts or are you reusing the old ones?
bill555
PostPosted: Mon Feb 27, 2017 1:05 pm Up
Hi,
They are the original bolts, all well in spec, threads cleaned, engine oil on thread and under cap. block threads chased and cleaned. I appreciate that this is a friction problem with this one bolt, could be bolt or block threads or both. With hindsight I would have used new bolts, I need to put this down as a learning exercise and work out how to proceed from the point I'm at.
Bill
bc
PostPosted: Mon Feb 27, 2017 2:13 pm Up
Could always nibble a few mm of the bottom of that bolt with Mr hacksaw
gazza82
PostPosted: Tue Feb 28, 2017 5:44 pm Up
Not something down the bolt hole? Swarf, dirt, etc?
bill555
PostPosted: Tue Feb 28, 2017 6:11 pm Up
No nothing down the bolt hole
Bill
bc
PostPosted: Tue Feb 28, 2017 7:45 pm Up
I would never reuse stretch bolts even if they are within spec. New bolts cost very little.
bill555
PostPosted: Tue Feb 28, 2017 8:59 pm Up
No need to convince me but what's done is done, I need to work out the best way to recover the situation.
Bill
bc
