Online Now [818]:
Visitors: 817
Today: 124836
Total: 154143496
Forums › The Car › 206 Problems › 206 Speedo
206 Speedo
Sami8303
PostPosted: Fri Mar 10, 2017 3:08 pm Up
Hi,
I've got 206 1.4 petrol, 2004. Speedo is cheating, it's showing 30 miles less, I think problem is that the speed arrow has moved back. Will it helps if I change whole clocks unit or problem is somewhere else?
PostPosted: Fri Mar 10, 2017 3:37 pm Up
Is the speedo showing the wrong speed OR is the mileage / trip reading incorrect?
Sami8303
PostPosted: Fri Mar 10, 2017 4:15 pm Up
speedo showing the wrong speed all the other clocks are OK
commandosqueak
PostPosted: Sun Mar 19, 2017 5:14 pm Up
The best thing to do is carefully remove the needle and stick it on when you know its correct. Hard to do unless you have something else to tell you how fast you are going. satnavs normally can do this as can an app with the GPS in mobile devices
2003 206 1.4 HDi (3 Door) LX - Cypress Green - KQM
2003 206 SW 2.0 HDI Grey
Sami8303
PostPosted: Fri Mar 24, 2017 3:34 pm Up
Hi,
Thanks commandosqueak.
All sorted, I've just moved needle anticlockwise in to the position of 0mph and now it's working perfect. I've checked it with my mobile with GPS app.
commandosqueak
PostPosted: Fri Mar 24, 2017 8:35 pm Up
glad you got it sorted
